You have implemented mutual route redistribution between OSPF and EIGRP on a border router. When checking the routing table on one of the EIGRP routers within the EIGRP routing domain, you are seeing some, but not all of the expected routes. What should you verify to troubleshoot this problem? Select the best response.
A. The border router is using a proper seed metric for OSPF.
B. The border router is using a proper seed metric for EIGRP.
C. The administrative distance is set for OSPF and EIGRP.
D. The missing OSPF routes are present in the routing table of the border router.
E. The subnet keyword on the border router in the redistribute OSPF command.
![bigeyes.gif](https://www.thaicpe.com/bigeyes.gif)
