SP Mobility Technology Systems Engineer Representative
  • 14 Packet Service Cards are located in a fully loaded Cisco ASR 5000 chassis.
  • Combines 2G, 3G, and 4G SGSN into the same platform are the unique option differentiation that sets Cisco ASR 5000 apart from competitors.
  • On the Cisco ASR 5000, features which help to ensure high availability:
    inter-chassis redundancy
    no single point of failure
    virtual memory protects software tasks
  • Support for any access over any media technologies is the driving force behind Cisco Unified Carrier Ethernet and mobile backhaul.
  • Throughput, signaling, and latency is a major concern for service providers in regard to migration to flat IP backhaul.
  • Redundancy bus interconnects RCCs and line cards.
  • Packet service card has the resources to run multiple services.
  • Enable support for multiple GSS nodes that are clustered to provide high availability and critical redundancy is the main function of cluster mode support.
  • CDR stand for call detail record within the context of GTPP billing.
  • Characteristics of the high availability task:
    It is responsible for maintaining the operational state of tasks in the system.
    It triggers an event to the RCT subsystem to take corrective action.
  • System management cards and packet service cards are the types of card that fit into the front of the Cisco ASR 5000 chassis.
  • The online upgrade allows active sessions to be maintained until they are self-terminated (subscriber ends the session) or meets the optionally defined upgrade-limit values is a characteristic of the online software upgrade on the Cisco ASR 5000 Series.
  • SMC card is used in the Cisco ASR 5000 model to manage system functions.
  • Cisco ASR 5000 can be marketed for all 3G and 4G deployments.
