The network uses EIGRP. Identify three characteristics of EIGRP feasible
successors? (Select three)
A. Traffic will be load balanced between feasible successors with the same advertised distance .
B. If the advertised distance of the non-successor route is less than the feasible distance of
best route, then that route is identified as a feasible successor.
C. If the successor becomes unavailable, then the feasible successor can be used immediately
without recalculating for a lost route.
D. The feasible successor can be found in the routing table.
E. A feasible successor is selected by comparing the advertised distance of a non-successor
route to the feasible distance of the best route.
