Final Network Set authentication, frame-relay, NAT, DHCP
[li]set Authentication PPP
host xxx
username [ชื่อ router ที่จะติดต่อ] password [พาสเวิร์ด router ที่จะติดต่อนี้]
เข้าไปที่ int s 0/0/0
encap ppp
ppp authen chap[/li]
[li][/list]
set frame-relay
int s 0/0/0
encap frame
frame interface-dlci [ค่า dlci ที่ได้จาก ISP][/li]
[li]set DNAT
ip nat pool [pool name] pool-ip netmask [subnet]
access-list 1 permit pool-ip wildcard
ip nat inside source list 1 pool [pool-name]
int fa 0/0
ip nat inside
int s 0/0/0
ip nat outside[/li]
[li]set PAT
access-list 1 permit [network] [wildcard]
ip nat inside source list 1 int s 0/0/0 overload
int fa 0/0
ip nat inside
int s 0/0/0
ip nat outside
interface Ethernet0
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface Ethernet1
ip address 192.168.4.1 255.255.255.0
ip nat inside
interface Serial0
ip address 172.17.38.1 255.255.255.0
ip nat outside
ip nat inside source list 1 interface Serial0 overload
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.4.0 0.0.0.255
RouterX# show ip nat translations
Pro Inside global Inside local Outside local Outside global
TCP 172.17.38.1:1050 192.168.3.7:1050 10.1.1.1:23 10.1.1.1:23
TCP 172.17.38.1:1776 192.168.4.12:1776 10.2.2.2:25 10.2.2.2:25[/li]
[li]set staticNAT
ip nat inside source static [local ip] [global ip]
local ip = ไอพีของเครื่องข้างใน
global ip = ไอพีที่เครื่องข้างในจะใช้ออกไป[/li]
[li]set DHCP
ip dhcp ex [start ip] [end ip]
