You need to configure EIGRP on all routers within the network. Which two statements are characteristics of the routing protocol EIGRP? (Select two)
A. Updates are sent as broadcast.
B. Updates are sent as multicast.
C. LSAs are sent to adjacent neighbors.
D. Metric values are represented in a 32-bit format for granularity.
You have been tasked with setting up summarization in the EIGRP network. Which two statements are true about EIGRP manual summarization? (Select two)
A. Manual summarization is configured on a per interface basis.
B. When manual summarization is configured, auto-summarization is automatically disabled by default.
C. The summary address is assigned an administrative distance of 10 by default.
D. Manual summaries can be configured with the classful mask only.
E. The summary address is entered into the routing table and is shown to be sourced from the Null0 interface.
