640-802 Cisco Certified Network Associate (CCNA) Activities for Practice
CCNA 1
http://cisco.sunderland.ac.uk/CISCO_CCNA/Exploration1_English
1.7.1 Summary and Review
2.2.4 Network Representations
2.4.8 Comparing the OSI Model with the TCP/IP Model
2.6.1 Lab: Topology Orientation and Building a Small Network
2.6.2 Lab: Using Wireshark? to View Protocol Data Units
2.7.1 Summary and Review
3.2.3 Application Layer Services and Protocols
3.3.2 WWW Service and HTTP
3.5.1 Summary and Review
4.1.6 Segmentation and Reassembly - Divide and Conquer
4.2.5 TCP Session Termination
4.4.4 UDP Client Processes
4.5.3 Application and Transport Layer Protocols
4.6.1 Summary and Review
5.2.2 Why Separate Hosts Into Network? - Performance
5.3.7 Packet Forwarding - Moving the Packet Toward its Destination
5.4.3 Dynamic Routing
5.5.1 Lab - Examining a Device's Gateway
5.5.2 Lab - Examining a Route
5.6.1 Summary
6.1.3 Practicing Binary to Decimal Conversions
6.1.5 Practicing Decimal to Binary Conversion
6.2.2 Calculating Network, Hosts and Broadcast Addresses
6.2.3 Unicast, Broadcast, Multicast - Types of Communication
6.2.5 Public and Private Addresses
6.5.4 Determining the Network Address
6.5.5 Calculating the Number of Hosts
6.5.6 Determining Valid Address for Hosts
6.5.7 Assigning Addresses
6.5.8 Addressing in a Tiered Internetwork
6.6.3 Ping Remote Host - Testing Connectivity to Remote LAN
6.6.4 Traceroute (tracert) - Testing the Path
6.7.1 Lab - Ping and Traceroute
6.7.2 Lab - Examining ICMP Packet
6.7.5 Lab: Subnet and Router Configuration
6.8.1 Summary and Review
7.4.1 Follow Data Through an Internetwork
7.5.1 Investigating Layer 2 Frame Headers
7.6.1 Summary and Review
8.3.7 Wireless Media
8.5.1 Summary and Review
9.4.2 CSMA/CD - The Process
9.6.2 Ethernet - Using Switches
9.6.4 Ethernet - Comparing Hubs and Switches
9.8.1 Lab - Address Resolution Protocol (ARP)
9.8.2 Lab - Cisco Switch MAC Table Examination
9.8.3 Lab - Intermediary Device as an End Device
9.9.1 Summary and Review
10.2.3 Making WAN Connections
10.6.1 Lab - Creating a Small Lab Topology
10.6.2 Lab - Establishing a Console Session with Hyper Terminal
10.7.1 Summary and Review
11.1.6 IOS "Examination" Commands
11.1.7 IOS Configuration Modes
11.2.1 Devices Need Names
11.2.2 Limiting Device Access - Configuring Passwords and Using Banners
11.2.3 Managing Configuration Files
11.2.4 Configuring Interfaces
11.3.1 Test the Stack
11.3.2 Testing the Interface Assignment
11.3.3 Testing Local Network
11.3.4 Testing Gateway and Remote Connectivity
11.3.5 Tracing and Interpreting Trace Results
11.5.1 Basic Cisco Device Configuration
11.5.2 Managing Device Configuration
11.6.1 Summary and Review
CCNA 2
http://cisco.sunderland.ac.uk/CISCO_CCNA/Exploration2_English
1.1.1 Routers are Computers
1.1.4 Router Boot-up Process
1.1.5 Router Interfaces
1.2.1 Implementing Basic Addressing Schemes
1.2.2 Basic Router Configuration
1.3.2 Directly-Connected Networks
1.3.3 Static Routing
1.3.4 Dynamic Routing
1.3.5 Routing Table Principles
1.4.1 Packet Fields and Frame Fields
1.4.2 Best Path and Metric
1.4.3 Equal Cost Load Balancing
1.5.1 Cabling a Network and Basic Router Configuration
1.5.2 Basic Router Configuration
1.5.3 Challenge Router Configuration
2.1.3 Examining the Connections of the Router
2.2.3 Verifying Ethernet interface
2.3.1 Verifying Changes to the Routing Table
2.3.2 Devices on Directly Connected Networks
2.3.3 Cisco Discovery Protocol (CDP)
2.3.4 Using CDP for Network Discovery
2.5.3 Verifying the Static Route Configuration
2.6.2 Default Static Route
2.7.3 Solving the Missing Route
2.8.1 Basic Static Route Configuration
2.8.2 Challenge Static Route Configuration
2.8.3 Troubleshooting Static Routes
2.9.1 Summary and Review
3.2.1 Overview
3.2.2 IGP and EGP
3.2.5 Convergence
3.4.4 Directly Connected Networks
3.5.1 Identifying Elements of the Routing Table
3.5.2 Subnetting Scenario 1
3.5.3 Subnetting Scenario 2
3.5.4 Subnetting Scenario 3
3.6.1 Summary and Review
4.1.4 Routing Protocol Characteristics
4.4.1 Definition and Implications
4.5.1 RIP and EIGRP
4.7.1 Summary and Review
5.2.1 Basic RIPv1 Configuration
5.2.3 Specifying Networks
5.3.4 Passive Interfaces
5.4.5 Advantages and Disadvantages of Automatic Summarization
5.5.2 Propagating the Default Route in RIPv1
5.6.1 Basic RIP Configuration
5.6.2 Challenge RIP Configuration
5.6.3 RIP Troubleshooting
5.7.1 Summary and Review
6.4.1 Basic VLSM Calculation and Addressing Design Activity
6.4.2: Troubleshooting a VLSM Addressing Design
beries
New member
why can't i download the .pkt files? is there any other way to download it? any other website? i just need it for my review.. thanks a lot for the help..
toni montana
New member
howto download http://uppic.net/iu/6962untitled.jpg
Quote:
Hi,
How come I can not download the lab solution for CCNA 2. Please advice.
Thanks.
I'm sorry server file has expire. If you have question about network. You can add question in this topic. We can help you
save_pp
New member
Please help me!
I can't download 10.3.1: Packet Tracer Skills Integration Challenge (Link-State Routing Protocols) and it is very important for me to see the solution of this.
Please reupload it or give another link.
refeel
New member
หุหุ เห็นว่าเทอมสองนี้จารย์อิดแก จะไม่เอาเรื่อง routing พวก rip igrp eigrp แต่เห็นว่าจะไปสอน switching แทน พวก vlan etherchanel อะไรประมาณนี้
etherchannel ด้วยเรอะ ดีๆ สงสัยอะไรก็ถามมาและกันคับ ถามแกดูพี่มี academy ccnp 5.0 อยู่ แกจะเอาไปสอนมั้ย จะได้ไปนั่งเรียนด้วย
brb
New member
Can you please reupload the solution to 9.7.1: Packet Tracer Skills Integration Challenge Activity (EIGRP)? I'd really appreciate it.
Thank you.
echelon
New member
รู้สึกว่าท่านจะเริ่มดังแล้วนะท่านปืน มีคนมาขอ Activities ที่ท่านทำเยอะเชียว
วิชา Advance topic of computer network ใช่รึปล่าว เพราะเนื้อหาที่สอนก็คือ CCNA 3 กับ 4 น่ะแหละ ก็เป็นเรื่อง Switching กับ WAN น่ะ นั่ง config กันมันส์มาก ขอบอก หุๆๆๆ
refeel
New member
ก้อยังไม่แน่ใจเหมือนกันอ่ะคับ จริงๆมันต้องเป็น CCNA2 ก่อน แต่แค่แว่วมาเฉยๆ ว่าแกจะสอนพวกนั้น งุงิ
echelon
New member
CCNA 2 ก็อยู่ในวิชา Network lab นั่นแหละ แต่เรียนตอนปลายภาคนะ แล้วก็หวังว่าคงจะไม่เจอข้อสอบปฏิบัติขั้นเทพแบบที่พวกพี่เจอนะ (ให้ตาราง Routing table มา สร้างโทโปโลยีจากตาราง แล้วก็คอนฟิคเราท์ติ้งให้ได้ค่าตามตาราง โดยทั้งหมดนี้ ภายในเวลา 2 ชั่วโมง
อันนี้พูดจากที่พวกพี่เรียนกันนะ ส่วนของ 49 นี่พี่ไม่รู้อ่ะว่าแกจะสอนยังไง ???
refeel
New member
แบบที่พี่นัทพูด แกให้ใช้พวก Routing Protocol ในการทำใช่ป่ะคับ ถ้าฝช่ผมว่ามันไม่ยากอ่ะคับ แต่แค่มันเยอะ 555+
