You need to enable BGP within your enterprise network. Which two statements are true regard
BGP? (Select two)
A. BGP is designed to scale only to large companies.
B. The UDP protocol is used for speed and low overhead.
C. BGP will never send a message unless it is triggered update.
D. The TCP protocol is used for reliability.
E. BGP is a path vector routing protocol.
F. BGP is a distance vector routing protocol.
BGP? (Select two)
