You is in the process of migrating from IP version 4 to version 6. Which two statements
are true about using IPv4 and IPv6 simultaneously on a network segment? (Select two)
A. IPv6 provides for more host IP addresses but IPv4 provides for more network addresses.
B. Host configuration options for IPv4 can be either statically assigned or assigned via DHCP.
Host configuration options for IPv6 can be statically assigned only.
C. IPv4 and IPv6 addresses can be simultaneously assigned to a host but not to a router
interface.
D. IPv6 allows a host to create its own IPv6 address that will allow it to communicate to other
devices on a network configured via DHCP. IPv4 does not provide a similar capability for
hosts.
E. Hosts can be configured to receive both IPv4 and IPv6 addresses via DHCP.
interface.
hosts.
