You need to determine the best tunneling method to use within your IPv6 netwoek. Which
statement best describes the difference between a manually configured IPv6 in IPv4 tunnel
versus an automatic 6to4 tunnel?
A. An automatic 6to4 tunnel does not require dual-stack (IPv4 and IPv6) routers at the tunnel
endpoints.
B. An automatic 6to4 tunnel allows multiple IPv4 destinations.
C. A manually configured IPv6 in IPv4 tunnel allows multiple IPv4 destinations.
D. A manually configured IPv6 in IPv4 tunnel does not require dual-stack (IPv4 and IPv6)
routers at the tunnel endpoints.
E. None of the other alternatives apply.
endpoints.
