Refer to the exhibit. A Boston company bought the assets of a New York company and is trying to route traffic between the two data networks using EIGRP. The show command output shows that traffic will not flow between the networks. As a network consultant, you were asked to modify the configuration and certify the interoperability of the two networks. For traffic to flow from subnet 172.16.8.0/24 to the 172.16.16.0/24 subnet, which configuration change do you recommend?
A. Turn off autosummarization on routers N1 and B1
B. Add IP summary addresses to the Internet-pointing interfaces of routers N1 and B1.
C. Turn off autosummarization on routers N2 and B2
D. Add wildcard masks to the network commands on routers N2 and B2.
