Which three conditions can cause BGP neighbor establishment to fail? (Select three)
A. There is an access list blocking all TCP traffic between the two BGP neighbors.
B. The EBGP neighbor is not directly connected, and the ebgp-multi-hop option is set to the
default value
C. The IBGP neighbor is not directly connected.
D. BGP synchronization is enabled in a Transit AS with fully-meshed IBGP neighbors.
E. The BGP update interval is different between the two BGP neighbors.
F. The BGP neighbor is referencing an incorrect AS number in its neighbor statement.
default value
