You are using multiple routing protocols in different Autonomous Systems (AS) within the
network domain. You need to redistribute between the systems. You are using
two-way redistribution but you want to ensure a loop free topology. Which action should help
you avoid routing loop issues?
A. Manually configuring the administrative K-factor
B. Manually configuring the administrative distance
C. Manually configuring the static routes
D. Manually configuring the default gateway
E. None of the other alternatives apply
