Refer to the exhibit. In a redundant hub-and-spoke deployment using EIGRP, what feature can be used to ensure that routers C through F are not used as transit routers for data traveling from router B to network 10.1.1.0?
A. Use address summarization at routers C, D, E, and F.
B. Use the EIGRP Stub feature on routers C, D, E, and F.
C. Use passive-interface on the spoke links in routers A and B.
D. Change the adminis trative distance in router A and B for routes learned from routers C, D, E, and F.
