The command “ clear ipv6 ospf process ” was issued on a router. What does this
command accomplish?
A. The route table is cleared. Then the OSPF neighbors are reformed.
B. The OSPF adjacencies are cleared and initiated again.
C. The OSPF database is repopulated and then the shortest path first (SPF) algorithm is
performed.
D. The shortest path first (SPF) algorithm is performed on the LSA database.
E. None of the other alternatives apply
command accomplish?
performed.
