The variance value is configured as 2, how many paths will be load balanced ?
Refer to the exhibit. ROUTE.com has just implemented this EIGRP network. A network administrator came to you for advice while trying to implement load balancing across part of their EIGRP network.
If the variance value is configured as 2 on all routers and all other metric and K values are configured to their default values, traffic from the Internet to the data center will be load balanced across how many paths?
Select the best response.
A. 1
B. 2
C. 3
D. 4
E. 5
