Your switch network has been configured to support multiple VLANs. In order for the users on one VLAN to communicate with users on another VLAN, which additional configuration is required?
A. Enable a routing protocol like EIGRP on a router or on a Layer 3 capable switch
B. Enable a switch virtual interface on the switch, using the encapsulation dot1q
C. Enable a switch virtual interface on the router, using the interface vlan global configuration command
D. subinterface configuration command
E. Enable IP routing on a Layer 2 switch
F. Enable inter-VLAN routing on a router or on a Layer 3 capable switch
