Refer to the exhibit. Router RTA is the hub router for routers RTB and RTC. The Frame Relay network is configured with EIGRP, and the entire network is in autonomous system 1. However, router RTB and RTC are not receiving each other's routes. What is the solution?
A. Configure the auto summary command under router eigrp 1 on router RTA.
B. Issue the no ip split horizon command on router RTA.
C. Configure subinterfaces on the spoke routers and assign different IP address subnets for each subinterface.
D. Check and change the access lists on router RTA.
E. Issue the no ip split horizon eigrp 1 command on router RTA.
F. Configure a distribute-list on router RTA that allows it to advertise all routes to the spoke routers.
