NE Router(NE20/40/40E/80E/5000E),ME60,CX600,Ethernet LAN switch(S9300/S5300/S3300/S2300),.:
support.huawei.com/support
VPLS:
support.huawei.com/enterprise/productNewOffering?idAbsPath=7919710|21782036|21782103|21782135|9017384&pid=9017384&from=soft&productname=eNSP
Configuring a Martini VLL (xconnect) to Access an L3VPN:blog.network-solution.net/configuring-a-martini-vll-to-access-an-l3vpn
Configuring a VSI (VPLS) to Access an L3VPN:
VPLS:
- Default PW can't talk to each other.
- use upe command to change the default behaviour.
- configure > system-view
- do sho run int x/x > display this
- exit > quit
- no > undo
- router ospf 1
vrf X
area 0
interface TenGigE0/0/1/0
interface TenGigE0/0/1/1
ospf 1 vpn-instance X
area 0.0.0.0
network 0.0.0.0 255.255.255.255
- show interface status > display interface Ethernet brief
- show inventory > display esn
- show ip interface brief > display ip interface brief
- show run > display current-configuration
- show vrf all > display ip vpn-instance
- vrf X > ip binding vpn-instance X
- write erase > reset saved-configuration
- Configure an IP address for physical interfaces and loopback interfaces.
- Create VE2/0/2 to terminate the MPLS L2VPN: 2/0 means use throughput of slot 2
system-view
sysname NPE
interface virtual-ethernet2/0/2
ve-group 1 l2-terminate
quit
Create VE2/0/3 to access the MPLS L3VPN.
interface virtual-ethernet2/0/3
ve-group 1 l3-access
quit
After the configuration is complete, run display virtual-ethernet ve-group command. To view the binding relationship between VE interfaces and a VE-group.
- Run an IGP on the VSI access network. ISIS is used in the example.
- BGP Basic:
interface Ethernet0/0/0
ip address 192.168.12.1 255.255.255.0
bgp 100
peer 192.168.12.2 as-number 200
network 2.2.2.0 24
>display bgp peer
>display bgp routing-table
>display ip routing-table
- BGP IBGP/EBGP Local Preference MED:
ospf
area 0
network 192.168.12.0 0.0.0.255
bgp 100
peer 2.2.2.2 connect-interface LoopBack0 : update-source
peer 1.1.1.1 next-hop-local : next-hop-self
- Static Route with track NQA (NQA: Cisco IP SLA):
nqa test-instance
test-type icmp
destination-address ipv4
frequency
start now
ip route-static track nqa
nqa test-instance x 1
test-type icmp
destination-address ipv4 1.1.1.1
frequency 10
start now
ip route-static 2.2.2.0 255.255.255.0 3.3.3.3 track nqa x 1
display nqa results
If nqa destination-address is unreachable, it won't appear in the routing-table
- Introduction:
forum.huawei.com/enterprise/forum.php?mod=viewthread&tid=200095
- Switching, Address:
forum.huawei.com/enterprise/forum.php?mod=viewthread&tid=215113
- Packet Receiving:
forum.huawei.com/enterprise/forum.php?mod=viewthread&tid=218321
- Traffic Control:
forum.huawei.com/enterprise/forum.php?mod=viewthread&tid=218431
- QoS Basics(1):
forum.huawei.com/enterprise/forum.php?mod=viewthread&tid=219729
- QoS Basics(2):
forum.huawei.com/enterprise/forum.php?mod=viewthread&tid=219777
- QoS Processing:
forum.huawei.com/enterprise/forum.php?mod=viewthread&tid=220011
- Fragmentation & Reassembly, Multicast & Broadcast Replication, NAT, Packet Filtering / ACL, Policy-based Routing (PBR):
forum.huawei.com/enterprise/forum.php?mod=viewthread&tid=220197
- A journey of Protocol Packets:
forum.huawei.com/enterprise/thread-221889.html
- dis bgp vpnv4 vpn-instance abc routing-table peer 102.101.1.1
- interface Eth-Trunk1
description Link to Eth-Trunk1
port link-type trunk
port trunk allow-pass vlan 101 to 102
mode lacp
interface XGigabitEthernet0/0/2
description Link to X0/0/2
eth-trunk 1
