A Not enough space in NVRAM error message occurs when attempting to save the configuration because the configuration size is larger than NVRAM
Core Issue
The problem occurs when issuing a write memory or copy running-config startup-config command. Compressing the configuration may resolve this issue.
https://supportforums.cisco.com/docs/DOC-1841
Core Issue
