Drag and drop routing characteristics on left to the correct routing catagory.
  • Drag and drop the routing characteristics on the left to the correct routing catagory on the right. Not all options on the left are used.
    [table][tr][td]Each router builds a full topology table.[/td][td]|[/td][td]static routing[/td][/tr]
    [tr][td]Each router sends periodic updates of the routing table to neighbor routers.[/td][td]|[/td][td][/td][/tr]
    [tr][td]support hierarchical area design[/td][td]|[/td][td]distance vector routing protocols[/td][/tr]
    [tr][td]require the most explicit configuration and the most maintenance[/td][td]|[/td][td][/td][/tr]
    [tr][td]also known as "routing by rumor"[/td][td]|[/td][td][/td][/tr]
    [tr][td]use attributes like local preference, weight, and so forth to determine the best path[/td][td]|[/td][td]link-state routing protocols[/td][/tr]
    [tr][td]support multiprotocols including VPNv4[/td][td]|[/td][td][/td][/tr]
    [tr][td]use for interdomain routing[/td][td]|[/td][td][/td][/tr][/table]
    A.
    B. Each router sends periodic updates of the routing table to neighbor routers.
    C. use attributes like local preference, weight, and so forth to determine the best path
    D. Each router builds a full topology table.
    also known as "routing by rumor" 8)
