How would be BGP updated that come from other autonomous system ?
  • Refer to the exhibit. On the basis of the configuration that is provided, how would the BGP updates that come from router R1 be replicated inside autonomous system 65200?
    Select the best response.
    A. All BGP updates that are received on router R2 will be sent to router R3 and R4. Routers R3 and R4 will then forward those BGP updates to router R5.
    B. All BGP updates that are received on router R2 will not be sent to routers R3 and R4.
    C. All BGP updates that are received on router R2 will be sent directly to router R5.
    D. None of the BGP updates that are received on router R2 will ever be received by router R5. 8)
