What should be done to correct this problem redistribution into RIP ?
  • Refer to the exhibit. Routers R1 and R2 have been configured to operate with OSPF. Routers R1 and R3 have been configured to operate with RIP. After configuring the redistribution between OSPF and RIP on R1, no OSPF routes are distributed into RIP.
    What should be done to correct this problem?
    A. The redistribution command should be reentered with the match route-type parameter
    B. The redistribution command should be reentered with the route-map map-tag parameter
    C. The redistribution command should be reentered with the metric metric-value parameter
    D. Routes will first need to be distributed into another protocol, and then into RIP. 8)
